Lightburn will not load, Just stopped. Try's to start
I downloaded the software on trial and was learning to use. When the software stopped working. When I click on the icon it begins to start and stops. On my toolbar I can see Lightburn icon saying untitled and just show white or blank, All I can do is click the X and it closes. Will not finish startup. Have uninstalled the software and reinstalled, does not fix the problem. What can I do to fix?
Reboot your computer. Then try to launch LightBurn again. If you continue to find an issue, take a screenshot and share that here, so we can “see” what you do. We can go from there. :slight_smile:
This all it does, this is on my toolbar at the bottom. Lightburn software begins to open and start the software and stops here.
Anyone out there who can help me with my problem?
Did you try rebooting the computer as I suggested? Open the Task Manager to see what is running. Close any LightBurn that is still running and please try again. :slight_smile:
Try re-running the program while holding the Shift key. Did you recently unhook a 2nd monitor?
Thank you, the Shift key worked.
