Lightburn Without Internet
Hi,
There’s no Internet where the laser is installed, nor any phone signal. Is that going to be a problem, if I get the software installed on the PC before taking it to site?
Thanks, Tony S
No issue. You can also ask support for an offline activation method, but if you can install at a site with internet access, things are easy. You don’t need access afterward.
Thanks. We should have a licence for three (or maybe two) installations, but at the moment the guy who dealt with ordering the machine seems to be AWOL.
I might have to do the initial setup without. Do you happen to know when the trial period starts, is it from time of download, or does it only start from installation or first use?
We not at that stage yet, still a bit of physical work on extraction, cooling etc.
Thanks.
Most of this stuff, is in the Documents and check there first. If you have issues, especially with a trial, I suggest you post here and if it’s business, might contact Lightburn support. This is especially true if the person that purchased it dumped you.
As far as I know, when you enable the software, you countdown of the trial should start. One of the Lightburn people needs to confirm this.
I have a OMTech China Blue, that’s 50W. It lives in the garage and has no internet or other wiring there except power.
I have a low cost TP-link bridge, it’s out with the laser. Works well, seems to be more tolerant of the weather than the previous PI’s.
If you have a PI laying around, you can load it with Lightburn Ruida setup, which helps communications with the Ruida.
I went through two of them and, at the time, they were so expensive I purchased a $12 bridge from Amazon. It’s been a while and they are more expensive than they were a number of years ago.
If you have issues, sing out.
:grinning_cat:
Hi Tony,
The trial period starts from when you first activate the trial. You get a 30 day trial, and can extend the trial up to 3 times for 15 days each. A standard license allows for three installations.
As Melvin said, we do offer offline activation, or you can activate in a location with internet access. You can see directions here: License Management Guide - LightBurn User Guide . The free trial can’t be activated or extended offline, but can still be used offline once activated.
From what you said about the guy who ordered the machine being AWOL, it sounds like you might need help getting hold of your license key. If you don’t have access to the purchase confirmation email or the login info for the license management portal, you can reach out to support at support@lightburnsoftware.com for help.
