I’ve set up Lightburn and the Omin1 but it says Disconnected. I’m sure this is an easy fix but I can’t figure it out. This is my first Galvo laser, btw.
Congratulations and welcome, glad you found Lightburn and this forum.
Did you import the laser manufacturer´s settings?
Some LightBurn documents regarding Galvo setup:
I figured it out. After following the instructions in the ComMarker instruction book, (made sure I did it correctly by watching some YouTube videos) I still couldn’t get Lightburn to connect to the laser. It appeared in Lightburn as a device but said disconnected. I uninstalled and reinstalled Lightburn and it worked. The laser was on during the uninstall and reinstall, not sure if that mattered, but that is how I got it to connect. Hope this helps someone having the same issue.
