Lightburn won't find COM after update
Hi!
I just installed the latest update and after reboot i can’t find any COM port. There was a issue when installing since i needed to end the task “COM Surrogate” first.
The laser connects as usual and i have tried it on Laser GRBL with no issues.
I have seen ppl recommend to add a device manually, but that makes no difference.
Any ideas?
Thanks in advance!
/John
If LaserGRBL can connect to the laser, LB can as well. So there is no driver issue. Maybe do the update again. Then add the laser manually, as USB type. Then you can select the port after it has been added.
Thanks for your input.
I have reinstalled the software several times and also a older version that has worked before. I have rebooted both computer and device several times. Even when added manually there is no COM port to select - the list stay empty.
That means Windows is not seeing the controller board. Power up the laser. Does the USB port appear in Computer Management, Device Manager in Windows when you plug the USB cable in?
