I’ve got a 100 watt machine. I’m doing some engraving of photos MDF that has the white (similar to dry-erase) coating.
I’m using dithering. I’ve found that some of the photos require tweaking (lightening/darkening) before bringing into lightburn and dithering.
Is there a way to do this within lightburn? And if not - is there a super easy workflow you could recommend? I have a process myself, but I need to do it on 200 different photos. and I’m hoping there is a quicker way.
LightBurn does provide image adjustments which can be found on the ‘Shape Properties’ page shown below.
LightBurn does not provide an automated way to adjust 200 images in a single go. If this is what you are after, you will need to use an image tool with those features first.
