Lighturn + Neje A40640
Hi everyone!
I just finished preparing my “home” machine by installing the NEJE A40640 laser with ARDUINO ONE.
I mainly have two problems:
1- when I do the cutting test it reaches 40% and then on the test card it goes OFF.
2- when I try to make the laser work by drawing a square, the laser turns on for an instant and then goes OFF.
I add some information that may perhaps help:
a - I am using the TEST BOARD provided by NEJE
b - I’m using LightBurn 1.5.04
c - I am using ARDUINO ONE
d - I have loaded the GRBL 1.1F firmware
e - The laser is NEJE A40640 40W (15W output)
Below are the values after entering the $I and $$ commands:
[VER:1.1f.20170801:]
[OPT:V,15,128]
Target buffer size found
ok
$0=10
$1=25
$2=0
$3=0
$4=0
$5=0
$6=0
$10=3
$11=0.010
$12=0.002
$13=0
$20=0
$21=1
$22=1
$23=0
$24=25.000
$25=500.000
$26=250
$27=1.000
$30=255
$31=0
$32=1
$100=160.256
$101=160.256
$102=250.000
$110=500.000
$111=500.000
$112=500.000
$120=10.000
$121=10.000
$122=10.000
$130=400.000
$131=400.000
$132=400.000
ok
Sorry for my English and my lack of knowledge but I’m a beginner.
Marco
In your device settings what is this set at.
It needs to match this number
the value in setting and $30 is the same.
at the beginning I started with firmware 0.9 and I could modify only the setting number. Now with v.1.1f i’m qualified to changhe $30-$31-$32.
in any way, even using Test instead of TTL, as soon as I bring the power above 40 it goes OFF.
and now unlike before, as already written, if I try to start a simple drawing with max power 255 as soon as the engraving starts it comes off.
