Limit switches /camera alignement error
Its frustrating that. I added limit switches to my ray5. Now lightburn wont frame. Its saying error too close and it stop when i hit frame. But when i hit start, it starts burning but stops at the 2nd burn saying the machine exceeded the working speed. Its going at 6000mm/min everytime it sops at the end of second placement of crosshairs. Any thoughts?
Are you exceeding your boundaries of only the burn or burn plus over run - area where the head has to slow down? (acceleration and deceleration). I get issues if I place the cut too close to my edges.
Do you now use Absolute Coords? With limit switches and this option, where you place your part in the Lightburn worlspace is where it will burn in the laser workarea.
Use the Preview window (turn on Show traversal moves) to see if Overscan is taking you outside the green box.
