I am getting down to the nitty gritty, and my mouse may not have the fine adjustment to do this. I added a polygon as a tail to this cat. If you look closely at the top, bottom and inner curve of tail, I have a few bumps. I am using the Bézier curve tool, but I can’t get out the little bumps. I may re-adjust this thing a few times and create new curves. Is there a “smooth tool”
cat polygon.lbrn2 (29.1 KB)
that I am missing?
I had a quick look, if you use the edit nodes tool you can highlight over the nodes you don’t want and delete with the “d” key, that might help a bit.
This is a little smoother
cat polygon_RRU.lbrn2 (21.7 KB)
There is a smooth tool under Edit → Optimize selected shapes.
Thank you for doing that. I was also told about the optimize tool.
