Hello, I am making a box. I draw with illustrator and import into lightburn. But for the “cutting” layer I have a problem. The line is interpreted as two lines! Can you help me solve this question?
Thanks
LightBurn works in wireframe mode. If you add a stroke, fills or line width to your source art, you will get these results. Set the line weight very small, some use as small as 0.01, remove any fills and you should get what you are after.
Let us know how you progress, and we can go from there.
Yes !!! Thanks it’s working perfectly !
