I’m setting up LightBurn for my new Boss LS1420 and am getting strange results when trying some very basic shapes. I draw a circle, set the speed to 10mm/s and power to 85%. If I select line mode, it barely gets through the paper masking on my material. If I select fill mode, the material is completely vaporized (row by row) and I’m left with a circle hole in my material. This tells me that when in line mode, those settings should have no problem getting through the material.
Am I missing a completely obvious setting somewhere that my line won’t cut through material while a fill on the same settings obliterates it?
Minimum power settings kick in at 10mm/s on Ruida controller. Is that what Boss uses? Set the speed to 11mm and see if there is a difference. If so, adjust your min power level.
That’s the controller manual. You’re more likely to find an explanation in the RDWorks software manual, if you can comprehend it:
For cutting processing, the actual power is followed with cutting speed, lowers peed, lower energy, high speed high energy, so that we can guarantee the whole process of cutting energy evenly. So the minimum power corresponding to the energy at minimum speed, generally the minimum speed is 0, but if set takeoff speed, so the minimum speed is takeoff speed; the maximum power corresponds to the layer speed.
