I have an image that I added a text above. When I go to the cuts/layers tab and choose “Line” the text burns where it should. When I click on “Fill” the text get’s burned an inch higher up. On the computer it show’s the txt where it is supposed to be. I cannot figure out why it is changing the txt location only on the board.
A pic would help, as would information about the job, speed, layers, machine, etc.
And on a low-powered machine, they typically have 8-bit controllers. Using inches adds rounding errors going from inch to mm and back. Not a whole inch worth, usually, but we have no idea what your job is.
If you JUST send the text, not the image, in both line and fill, does it offset?
