Welcome and thanks for the post. The movement lines don’t turn off because you don’t have laser mode enabled, or possibly because your spindle max setting ($30) doesn’t match the setting in LightBurn 1000 is the default in LightBurn and in GRBL, but some software changes it. You can see your GRBL settings by typing $$ in the console and pressing enter. This is what they all mean: https://github.com/gnea/grbl/wiki/Grbl-v1.1-Configuration
Share your grbl settings and we can go from there.
Thank you! Here are my settings:
$0=10
$1=25
$2=0
$3=2
$4=0
$5=0
$6=0
$10=1
$11=0.010
$12=0.002
$13=0
$20=0
$21=0
$22=0
$23=0
$24=25.000
$25=500.000
$26=250
$27=1.000
$30=1000
$31=0
$32=0
$100=800.000
$101=800.000
$102=800.000
$110=1000.000
$111=1000.000
$112=600.000
$120=30.000
$121=30.000
$122=30.000
$130=200.000
$131=200.000
$132=200.000
ok
How would I enable laser mode?
Thank you, it now says $32=1, is that correct?
Yes, if you want to set Laser Mode to ON.
Great! It worked, thanks for the support!
