I have an image that I have duplicated 8 times on the same work area. The problem is the laser is leaving a line between images. This just started today after I load a new version of Lightburn software. Is there a setting that will stop that??
Rick
(Technical Evangelist)
November 17, 2020, 2:10am
2
GRBL 1.1f and later have laser mode, set by $32=1. My guess is you do not have your firmware set correctly.
Have you had a chance to review this?
In the post above ^^^, I offered the following link. This is worth review.
The summary:
Turn on Laser Mode to get rid of the travel lines
You’re trying to move too fast, which is why you don’t get enough power
You need to zero the machine
3018’s are pre-configured for use as CNC machines, not lasers, so their settings and speeds will likely need to be changed to give you acceptable results with LightBurn.
To see the existing settings, you can type $$ into the console in LightBurn and press enter, or go to Edit > Machine Settings. Both are showing the same values, b…
system
(system)
Closed
December 17, 2020, 2:10am
3
