Hi there!
I´m new at this laser thing. Hope you can help me improve my results.
I’m getting this results as shown in the pic below.
The start of every line doesnt match the next passes…
And the circle isnt as perfect as it should be…
Any hint?
You’re losing steps somewhere:
Here is a guide to check the mechanics of a Sculpfun laser: Guide to mechanical adjustments and maintenance - Diode Laser Wiki
A quite common case with Sculpfun lasers is that the pulleys (small gears directly on the motors’ axis) are not tight. Check by tightening the small grub screws.
Thank you very much for your help.
It was the pulleys! One was completely loose.
