Lines in engraving on some pieces
I’m getting some definitive lines in my engraving work. Is it my lines per mm setting maybe?
Based on the image, I see lines in the bottom sign, but not the top one. Does this repeat in all following signs? Are the lines in about the same place each time?
Could be something in the wood or mechanical. I doubt the interval went wonky on you all of a sudden. If the second sign cannot be used, flip it over and try the backside.
The first one it did come out right. Then the next three had lines in the same spot. I would flip them over but they’re leather.
you might notice the distance of the little lines should be roughly 2 mm apart, therefore matching maybe the pitch of the belts
Make sure your belts and rails are 100% clean and no dust or similar has formed on belts or wheels
