Seems Lines/ inch should be labeled Dots per inch. Just sayin.
So, when I’m engraving text, which comes out as just lines, you think it should be called dots because … reasons?
Well, the crazy thing is that I saw the Label on the 1st box “Line Interval (mm)” and thought the Second box “Lines Per Inch” was somehow a pulse rate, forgetting also that they were locked to each other. So, please disregard : )
adding, that in effect, the final result of engraving is an array of dots and not really lines.
Non dithered engraving seems pretty much to be horizontal lines separated by a gap in Y, so “lines per” sounds right to me:-)
Cheers
David
The laser is pulsed> dots. Noticeable if you go fast enough. Noticeably thinner if you go faster or use less power as the highest energy part of the beam is in the center
