I’m new to Laser Engraving as well as Lightburn. I purchased a Sculpfun S9 and noticed that there is a noticeable offset in fills, where forward lines are shifted against backward lines. The offset disappears when engraving with bi-directional turned off, but of course this takes longer. The text shown in the comparison is a little over 1 mm in height. On larger text (as in the 5 mm example) the shifting leads to a minor blurriness.
I assume the shifting is caused by play in either the (rather tight) belt, the gear or the stepper motor.
Question is how this can be fixed? Is there a setting in Lightburn to compensate the play, so that forward and backward lines align?
Thanks for the swift reply. The offset is approx. 0.2 mm. I wonder if such an accuracy can even be achieved with such a cheap, belt driven engraver, or whether I’m just expecting too much.
How can I figure out whether it is a mechanical/backlash issue, or a timing issue firing the laser, as described in your linked Scanning Offset Adjustment instructions? I mean there is no obvious play as one could identify when moving e.g. two gears. It’s so minimal it’s extremely identify just from moving parts.
It’s the interaction between components where you’ll get your losses.
triple check your belts - If they’re taught as I’ve described then move on.
your pulleys will be either secured properly or not. What you don’t want happening is for their to be a little bit of slippage back and forth during direction changes. As long as the grub screw is secured to the flat portion of the stepper shaft you should be good. Then move on.
I don’t think this is the issue for you here but check the wheels on the rails. Is there any separation between the wheels and rail that’s causing slop in the motion? Is there any wiggling of the laser module on the gantry? If so, adjust eccentric nuts between the wheels and plate to close the gap. Do not overtighten this.
Once you’re relatively confident you’ve gone through the mechanism to reduce this then move on to the software adjustment.
