Lines on edge of engrave
At higher speeds 300-400mm/s these lines apear on all surfaces in both x and y directions…i have the power min set about 20% behind max.
Am i programming incorrectly?
Defocussing helps
I dont think its the belt considering its identical in both x and y and belts are tensioned properly as per manufacturer
60w CO2
Monport Ruida Controller
For your reading pleasure.
Thank you so much!!!
