how do I correct for the lines extending from the letter? I have tried different speeds and power lvls.
Using an Atomstack for burning only into wood products.
Any help would be much appreciated.
this could be backlash or something loose but it seems too consistent.
Check the belts and set screws first.
What speed have you selected? (in mm/min)
If you’re attempting to move faster than the engraver will allow, the Offset Scanning setting will produce some strange effects. In the Cuts / Layers window, click on the layer you are filling and see what these settings are.
