Hi All,
It’s the first time I have had issues with LightBurn on either of these 2 Linux Mint systems. Everything has worked fine thru 1.6.04. When installing any of the 1.7 releases I can see the following when I execute from the command line.
Any pointers would be greatly appreciated.
Regards,
Greg
Linux version 5.4.0-196-generic (buildd@lcy02-amd64-031) (gcc version 9.4.0 (Ubuntu 9.4.0-1ubuntu1~20.04.2)) #216-Ubuntu SMP Thu Aug 29 13:26:53 UTC 2024
Distributor ID: | Linuxmint |
Description: | Linux Mint 20.3 |
Release: | 20.3 |
Codename: | una |
./LightBurn: /lib/x86_64-linux-gnu/libstdc++.so.6: version GLIBCXX_3.4.29' not found (required by ./LightBurn) ./LightBurn: /lib/x86_64-linux-gnu/libc.so.6: version
GLIBC_2.32’ not found (required by ./LightBurn)
./LightBurn: /lib/x86_64-linux-gnu/libc.so.6: version GLIBC_2.34' not found (required by ./LightBurn) ./LightBurn: /lib/x86_64-linux-gnu/libc.so.6: version
GLIBC_2.33’ not found (required by ./LightBurn)
./LightBurn: /lib/x86_64-linux-gnu/libc.so.6: version GLIBC_2.34' not found (required by /usr/share/LightBurn/lib/libpulse.so.0) ./LightBurn: /lib/x86_64-linux-gnu/libc.so.6: version
GLIBC_2.32’ not found (required by /usr/share/LightBurn/lib/libpulse.so.0)
./LightBurn: /lib/x86_64-linux-gnu/libc.so.6: version GLIBC_2.33' not found (required by /usr/share/LightBurn/lib/libglib-2.0.so.0) ./LightBurn: /lib/x86_64-linux-gnu/libc.so.6: version
GLIBC_2.32’ not found (required by /usr/share/LightBurn/lib/libglib-2.0.so.0)
./LightBurn: /lib/x86_64-linux-gnu/libc.so.6: version GLIBC_2.34' not found (required by /usr/share/LightBurn/lib/libglib-2.0.so.0) ./LightBurn: /lib/x86_64-linux-gnu/libc.so.6: version
GLIBC_2.33’ not found (required by /usr/share/LightBurn/lib/libgssapi_krb5.so.2)
./LightBurn: /lib/x86_64-linux-gnu/libc.so.6: version GLIBC_2.33' not found (required by /usr/share/LightBurn/lib/libpulsecommon-15.99.so) ./LightBurn: /lib/x86_64-linux-gnu/libc.so.6: version
GLIBC_2.32’ not found (required by /usr/share/LightBurn/lib/libpulsecommon-15.99.so)
./LightBurn: /lib/x86_64-linux-gnu/libc.so.6: version GLIBC_2.34' not found (required by /usr/share/LightBurn/lib/libpulsecommon-15.99.so) ./LightBurn: /lib/x86_64-linux-gnu/libc.so.6: version
GLIBC_2.33’ not found (required by /usr/share/LightBurn/lib/libdbus-1.so.3)
./LightBurn: /lib/x86_64-linux-gnu/libc.so.6: version GLIBC_2.34' not found (required by /usr/share/LightBurn/lib/libdbus-1.so.3) ./LightBurn: /lib/x86_64-linux-gnu/libc.so.6: version
GLIBC_2.33’ not found (required by /usr/share/LightBurn/lib/libkrb5.so.3)
./LightBurn: /lib/x86_64-linux-gnu/libc.so.6: version GLIBC_2.34' not found (required by /usr/share/LightBurn/lib/libkrb5.so.3) ./LightBurn: /lib/x86_64-linux-gnu/libc.so.6: version
GLIBC_2.33’ not found (required by /usr/share/LightBurn/lib/libk5crypto.so.3)
./LightBurn: /lib/x86_64-linux-gnu/libc.so.6: version GLIBC_2.33' not found (required by /usr/share/LightBurn/lib/libkrb5support.so.0) ./LightBurn: /lib/x86_64-linux-gnu/libc.so.6: version
GLIBC_2.34’ not found (required by /usr/share/LightBurn/lib/libkrb5support.so.0)
./LightBurn: /lib/x86_64-linux-gnu/libc.so.6: version GLIBC_2.33' not found (required by /usr/share/LightBurn/lib/libsndfile.so.1) ./LightBurn: /lib/x86_64-linux-gnu/libc.so.6: version
GLIBC_2.33’ not found (required by /usr/share/LightBurn/lib/libsystemd.so.0)
./LightBurn: /lib/x86_64-linux-gnu/libc.so.6: version GLIBC_2.32' not found (required by /usr/share/LightBurn/lib/libsystemd.so.0) ./LightBurn: /lib/x86_64-linux-gnu/libc.so.6: version
GLIBC_2.34’ not found (required by /usr/share/LightBurn/lib/libsystemd.so.0)
./LightBurn: /lib/x86_64-linux-gnu/libc.so.6: version GLIBC_2.32' not found (required by /usr/share/LightBurn/lib/libasyncns.so.0) ./LightBurn: /lib/x86_64-linux-gnu/libc.so.6: version
GLIBC_2.34’ not found (required by /usr/share/LightBurn/lib/libasyncns.so.0)
./LightBurn: /lib/x86_64-linux-gnu/libc.so.6: version GLIBC_2.34' not found (required by /usr/share/LightBurn/lib/libapparmor.so.1) ./LightBurn: /lib/x86_64-linux-gnu/libc.so.6: version
GLIBC_2.33’ not found (required by /usr/share/LightBurn/lib/libapparmor.so.1)
./LightBurn: /lib/x86_64-linux-gnu/libc.so.6: version GLIBC_2.33' not found (required by /usr/share/LightBurn/lib/libFLAC.so.8) ./LightBurn: /lib/x86_64-linux-gnu/libc.so.6: version
GLIBC_2.32’ not found (required by /usr/share/LightBurn/lib/liblzma.so.5)
./LightBurn: /lib/x86_64-linux-gnu/libc.so.6: version GLIBC_2.34' not found (required by /usr/share/LightBurn/lib/liblzma.so.5) ./LightBurn: /lib/x86_64-linux-gnu/libc.so.6: version
GLIBC_2.33’ not found (required by /usr/share/LightBurn/lib/libcap.so.2)
./LightBurn: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.33’ not found (required by /usr/share/LightBurn/lib/libgcrypt.so.20)
