Hello,
I got a homemade machine, GRBL / arduino / CnC enable plasma . I got some interesting result but i got a a mechanic problem
i got a delay between the plasma starting and the torch navigating . Basically i got about 2 mm without cut ( 4 mm at the end of the cut ). I do use the overlapping option ( advanced ) to be able to finish the cut in full . It work for most of the cut . however, when i got a cut of less than 3 seconds ( a dot for exemple ), it will trigger the plasma but the plasma will not have the time to turn on . I would like to know if there is an option for putting some delay between the start of the travel and the start of the plasma . I ll try to put something like 12 mm overlapping cut see if it work . I m kust curious to know if someone got a suggestion
Thanks
Yes, look in the advanced tab of the layer settings.
