Kerf is the value used to compensate tool thickness.
If you cut through a piece of wood, the width of the slot, that is your kerf.
How do I decipher this file?
…" An ODS file is a spreadsheet created by Calc, a spreadsheet program included with the LibreOffice and Apache OpenOffice suites. It stores data in cells organized into rows and columns, and it may also contain charts, mathematical functions, and formatting. ODS files are similar to .XLSX files."…
After replacing “txt” with “ods” all spreadsheet programs should be able to import or directly open the file.
But, as I said, it’s just a simple percentage calculation.
((New size)/(old size)) * 100%
3.2/3 * 100 = 106~ish
thanks for answer ,good answer thanks
hi dean would you share your file or maybe sell it thanks
It is a very small primitive spreadsheet, you enter your starting dimension and what you want to get, nothing more or less.
Of course you are welcome to have the small file.
Depending on what type of spreadsheet you have (open office and co. or ms office) you select the file and just delete “.txt”
Come back if it doesn’t work.
Procentregning LightBurn.xlsx.txt (5.3 KB)
Procentregning LightBurn.ods.txt (10.8 KB)
