Location Coordinates
I have a Omtech 60w with the KT332N controller. I have noticed the x and y coordinates between the controller and Lightburn are not in sync. I move the laser head to the home position using Lightburn and the controller says x=0 and y=0, perfect. I ask Lightburn to get the position and it shows x=0 and y=0. Good so far. When I move the laser head, the coordinates shown in Lightburn after I hit get position and the coordinates on the controller are not the same, not close. I’m thinking they should be the same. Am I wrong? I looked at the settings, device settings and machine settings and did not see anything obvious to change. Please advise. Thank you…
Check for different Units (mm inch).click the button.
Yep, just that simple. Thank you.
