Logitech C920 no capturing nor can I change setting in LB
What version of LightBurn are you running? And you’re certain the device type is “GRBL”?
Network port should absolutely be a configurable value in Edit->Device Settings.
Oh my!!!
My LB version is 1.3.1 I think.
Not in front of my PC
You are truly a guru of LB.
Will try in there.
And yes, I use GRBL when selecting in device
Thank you so much for your knowledgeable feedback and specially your patience!!!
Will try once back from work.
:+1::+1:
I can’t remember specifically but it’s possible that it wasn’t configurable in that version.
All is good the 1.3.1 does have the port settings and it works correctly…
Thank you for your super help!!!
well appreciated!!
hello - I have exactly this issue with my C920 but I dont understand the instruction that you have listed for the fix. Could you explain how to do this please?
I had my preference file as “Read Only”.
once I disable the “read Only”, I was able to change the “SETTING” from custom to default.
note that even it worked, the resolution is not satisfactory, hence, I end up using other camera that I have laying around.
good luck!
