I have a logo I’m trying to trace on a tumbler. The image is tracing backwards. I just installed the piburn 4.0.
Swap ends of your rotary in the machine…
My PiBurn 3.0 did this. I swapped ends until I could open the plug up and swap the phases to the motor. Notice the motor is on the left… and all the controls are behind the Y gantry.
The two phases are crossed, so the rotary is rotating the wrong direction…
It needs to rotate the direction it would need to go to emulate the Y axes movement.
If the head moves toward you, then the rotary has to move away from you…
One you’re moving the head (Y axes), the other you’re moving the table (mug)…
Make sense?
That worked.
Thank you!
