Logo on tumbler is not scrunched up
Question i tried my rotory for the first time and my images are scrunched up on a tumbler in lightburn it shows 71mm x 141 mm but the actual engraving is coming out 71mm x 60mm.
You didn’t give any info about what type of rotary or laser you’re using but your rotary settings are wrong. Without knowing what you have we can’t advise. Post a screenshot of your rotary setuo screen along with the other info.
Make sure you have ENABLE ROTARY turned on…
Thank you for the replies I figured it out my settings were good except for the steps per rotation it was set a little less than half of what it should have been i corrected it and got the logo to mark the correct dimension.
Looks good!
