Longer b1 30w rotary x and y axis are swapped
I have a longer b1 30w laser, it has been working great with normal laser engraving but when i attach my rotary to the y axis cable the rotary moves with the x axis, there is no other way i can plug in the rotary so i know its connected correctly all adjustments i make to the rotary settings effect the laser head traveling in the y axis, what am i doing wrong?
If you connect the rotary and it moves with Xaxis commands, surely there is another way.
Let us do a quiz with the rotary connected. These are yes/no, not essay, questions…
Does the Xaxis move with the rotary?
Does the Yaxis move with Yaxis commands?
If your answers are No & Yes in that order, you have attached the rotary to the wrong axis.
