Longer B1 and a Longer Rotary tool
New to all this stuff, but fairly tech / mech comfortable.
Got the B1 30W setup and running with flat work. Trying to get the rotary tool to work. I plug it into the Y axis from the controller, launch LB, turn on the laser and then do the rotary setup. Click test and it errors out with Error 9. I clear that with $X and then $H to rehome as it suggests. I then get a hard limit alarm after the rollers spin for a couple of minutes.
What am I missing? From what I’ve seen, these things are supposedly fairly plug and play.
Here’s what gets pumped out
error:9
G-code locked out during alarm or jog state.
On or near line 0:
error:9
On or near line 0:
error:9
On or near line 0:
Stream completed in 0:00
error:9
error:9
error:9
error:9
error:9
ALARM:9
Homing fail. Could not find limit switch within search distance. Defined as 1.5 * max_travel on search and 5 * pulloff on locate phases.
ok
Grbl 1.1 [‘$’ for help]
FW:LGT V1.2.3|MB:LS_ESP32
ok
[MSG:‘$H’|‘$X’ to unlock]
[MSG:Caution: Unlocked]
ok
ok
ALARM:1
Hard limit triggered. Machine position is likely lost due to sudden and immediate halt. Re-homing is highly recommended.
You can’t home any rotaries that I know of… they do not have switches to indicate where home is…
You’ll have to run it in a manual mode…
