Hello . I need a firmware for longer b1 30w . I already have from original websites 202308… But after upgrade wont work air assist. I need newer or older. Thanks for all
Actually i have 2023080801.
Tell me, were you able to find these files?
Were you able to launch air assist?
Yes. You must edit parameters via lasergrbl program. Or import config file via lasergrbl program. Config file is in the zip file with firmware
I have found a solution to this problem. Use the B1 30W - LS ESP32 V1.3
Files. Both the firmware and config did work for me.
I played around with all sorts of .nc files and different firmwares and this is the only way I was able to make it work.
Small explanation:
In the Config Files provided on the homepage from Longer for the B1 40W, some parameters were missing. It doesn’t work to just use the config file and the firmware on the 40W page, it gives an error, that it doesn’t know what to do with the “new” additional parameters.
After I did this, I checked with the 40W config file for different entries and changed them.
With this Air Assist works in Lightburn for me.
Edit. I see now, that you made it work yourself, but I leave this here for maybe someone with the 40W Version and the same Problem.
I have a Longer B1 40w. This information does help. I need to update the firmware to get support for M4 commands. My question is what process did you use to update the firmware, on the longer site is only shows the process for upgrading firmware on the Ray5 mini, will that work for the B1 series ? Lots of youtube videos of the B1 Series unpacking, but nothing on doing a firmware upgrade.
Thanks
