"Longer" laser settings
Hi, I just purchased “Longer” laser, my problem is when it homes it doest stop but keeps on vibrating off the side bars, I can’t see any sensors, I’m thinking it may be a setting I need to open.
Thanks
Andrew.
What does your manual say about how to home your laser?
I can’t find the manual, thought I’d try the forum first see if this is a regular problem, I’m thinking it a settings problem.
Andrew
Start by finding out where the machine’s home is and whether LightBurn is set to it. Look for limit switches, typically they are in the lower left corner. In the picture are the settings as they are on the Longer I have been running, it doesn’t have to be the same as yours, be careful.
ps. There should be a settings file on the included USB stick.
