Longer Laser Will Not Shut Off
I’m not sure if this is a hardware of software issue.
I installed limit switches on my Longer Ray5 laser engraver and when I plugged it back in the laser was on and seemed to be at full power.
This was before connecting it to Lightburn.
It worked fine before I installed the limit switches and new wire harness.
So with that said, I removed the limit switches and re-installed to old wire harness and the laser will not shut off now with the original wire harness.
And it’s still not hooked up to Lightburn.
Help please.
Thank you.
I solved it.
Had it wired wrong.
Can I delete this post?
Yes, but others will learn more if you do not. Every solution is a win.
