Longer not performing as expected
My Longer B1 40 is no better than my Longer ray5 10w
I did a material test. To cut 3mm basswood 300mm @100% power. I can do that on my Ray5 10.
There’s barely 2 hours on this laser
In the console window enter $$ then look for the $30 value. Typically it is 1,000, but could be something else. Then Go to Device Settings> Basic Settings tab and verify that S-Value Max is the same as $30. It it isn’t, make the change to S-Value max so that both match. Also, verify that your speed is mm/min, not mm/sec or any other option.
When finished with everything @thelmuth said, then research what your focus point really is. They are not always exactly what the manufacturer recommends.
It is commonly thought that a 40w laser is 4x more powerful than a 10w laser. This is true, but it cannot cut 4x better. The dot at focus is much larger, so that 40w is spread out over a larger area. So the effective cutting power is not 4x that of a 10w.
I have both a 10w and a 40w/20w laser. In my rough estimate from experience, the 20w cuts 60% better than the 10w, and the 40w cuts 60% better than the 20w.
All that said, my 10w cuts 3mm using 800mm/m, 80% pwr, 5 passes. The 20w does it at 1200mm/m and the 40w does it at 2400mm/m, 90% pwr, and 6 passes. In all cases, the part falls free 99% of the time.
I hope this gives you some guidelines that help.
You have some tough wood. I cut 3.5mm with my 10w at 385mm/m at 100% in 1 pass. But I use cheap 3 layer underlayment.
Ha, ha. Just regular Baltic Birch from Amazon.
Ditto That.
I cut 3mm basswood ply from Amazon @ 300mm/m @80% power on my 10w laser in one pass.
Surprisingly, I found that 300mm/m @80% power takes less time than doing 800mm/m, 80% power with 5 passes. In other words - slower is faster
Not really. 1/3 the speed and 1/5 the distance.
My settings get me 100% cut through. Even when there is a fiberglass stringer in the wood.
My settings does too.
First of all, thanks for all the replies!
I did what Tim suggested in Lightburn.
Attached is a sample test on 3mm basswood with my B1 40.
As you can see at 300mm/m and 100% power to cut thru, where my 10 watt is doing equal. Both on honeycomb bed, B1 has only a few hours on it. Both have been focused by block with the 10 watt, and the foot on the B1.
Pretty disappointed. I was expecting it to be capable of cutting up to 1" as specs said. I would be fine if it was even 2 passes. I also wasn’t expecting to cut thru hardwood, but even as my test shows, takes a lot to cut 3mm.
Again, Thanks in advance everyone. Been lasering about 2 years. Knowledgeable but definitely
no expert
I have a 40w Sculpfun and would never expect it to cut 1” of any kind of plywood. Advertising often uses perfect conditions and the best result after many tries.
That’s the laser equivalent of those ‘Shot on iPhone’ commercials.
