jimsz
(jim)
1
I am unable to get my MacBook Air to connect to my Longer Ray 5 10w using Lightburn.
I don’t have a clue where the problemn could be.
I’ve searched he forums and have found nothing that has worked - anyone have any suggestions?
I have spent hours on this and am ready to just return the engraver. Mac support seems to be severely lacking.
gilaraujo
(Gil Araújo)
2
Apple Silicon MacBook Air?
if so you might need a cheap 2.0 USB Hub in between Mac and Laser
gilaraujo
(Gil Araújo)
4
Open a terminal
Unplug your USB cable
Type this command and press enter
ioreg -p IOUSB
Then plug the cable and power on the laser
Repeat command.
Post a image of both outputs please.
jimsz
(jim)
5
Output returned (both times) below
MacBook-Air:~ jim$ ioreg -p IOUSB
±o Root <class IORegistryEntry, id 0x100000100, retain 17>
±o AppleUSBEHCI Root Hub Simulation@1d000000 <class AppleUSBRootHubDevice, $
| ±o IOUSBHostDevice@1d100000 <class AppleUSBDevice, id 0x1000002a5, regist$
| ±o IOUSBHostDevice@1d180000 <class AppleUSBDevice, id 0x1000002ca, regi$
| ±o BRCM20702 Hub@1d181000 <class AppleUSBDevice, id 0x1000002e9, regi$
| | ±o Bluetooth USB Host Controller@1d181300 <class AppleUSBDevice, id$
| ±o Apple Internal Keyboard / Trackpad@1d182000 <class AppleUSBDevice,$
| ±o Internal Memory Card Reader@1d183000 <class AppleUSBDevice, id 0x1$
±o AppleUSBEHCI Root Hub Simulation@1a000000 <class AppleUSBRootHubDevice, $
| ±o IOUSBHostDevice@1a100000 <class AppleUSBDevice, id 0x1000002ac, regist$
| ±o FaceTime HD Camera (Built-in)@1a110000 <class AppleUSBDevice, id 0x1$
±o AppleUSBXHCI Root Hub Simulation@14000000 <class AppleUSBRootHubDevice, $
MacBook-Air:~ jim$
MacBook-Air:~ jim$ MacBook-Air:~ jim$ ioreg -p IOUSB
-bash: MacBook-Air:~: command not found
MacBook-Air:~ jim$ ±o Root <class IORegistryEntry, id 0x100000100, retain 17>
-bash: syntax error near unexpected token newline' MacBook-Air:~ jim$ +-o AppleUSBEHCI Root Hub Simulation@1d000000 <class AppleUSBRootHubDevice, $ -bash: class: No such file or directory MacBook-Air:~ jim$ | +-o IOUSBHostDevice@1d100000 <class AppleUSBDevice, id 0x1000002a5, regist$ -bash: syntax error near unexpected token |’
MacBook-Air:~ jim$ | ±o IOUSBHostDevice@1d180000 <class AppleUSBDevice, id 0x1000002ca, regi$
-bash: syntax error near unexpected token |' MacBook-Air:~ jim$ | +-o BRCM20702 Hub@1d181000 <class AppleUSBDevice, id 0x1000002e9, regi$ -bash: syntax error near unexpected token |’
MacBook-Air:~ jim$ | | ±o Bluetooth USB Host Controller@1d181300 <class AppleUSBDevice, id$
-bash: syntax error near unexpected token |' MacBook-Air:~ jim$ | +-o Apple Internal Keyboard / Trackpad@1d182000 <class AppleUSBDevice,$ -bash: syntax error near unexpected token |’
MacBook-Air:~ jim$ | ±o Internal Memory Card Reader@1d183000 <class AppleUSBDevice, id 0x1$
-bash: syntax error near unexpected token |' MacBook-Air:~ jim$ +-o AppleUSBEHCI Root Hub Simulation@1a000000 <class AppleUSBRootHubDevice, $ -bash: class: No such file or directory MacBook-Air:~ jim$ | +-o IOUSBHostDevice@1a100000 <class AppleUSBDevice, id 0x1000002ac, regist$ -bash: syntax error near unexpected token |’
MacBook-Air:~ jim$ | ±o FaceTime HD Camera (Built-in)@1a110000 <class AppleUSBDevice, id 0x1$
-bash: syntax error near unexpected token `|’
MacBook-Air:~ jim$ ±o AppleUSBXHCI Root Hub Simulation@14000000 <class AppleUSBRootHubDevice, $
