Longer ray5 - keeps on having movement protection error
I am continually getting this error:
ALARM:3
Reset while in motion. Grbl cannot guarantee position. Lost steps are likely. Re-homing is highly recommended.
On or near line 1:
Job halted
Stream completed in 4:09
ok
SimpleLaser 1.1h [‘$’ for help]
[MSG:‘$H’|‘$X’ to unlock]
[MSG:Caution: Unlocked]
im not surte what to do…please help!
Three possibilities:
  1. Bad USB connection or cable.
  2. Bad power supply or connector.
  3. A safety interlock (fire, door, tilt, etc.) is intermittent.
Although that seems to happen very early in the G-Code program, the message is generated after the fault and the Troubleshooting suggestion are relevant:
The laser halted abruptly, sometimes due to another Alarm or Error, or, often, the computer losing connection to the machine.
Check the Console for error messages preceding that one, as they may indicate the true problem.
