Longer Ray5 laser 10w
Hello. I have a Longer Ray5 laser with a 10W output. Initially, it worked fine and could cut through 3mm plywood at a speed of 260-300mm/min with 100% power. However, after approximately 10 hours of total operation time, with work intervals of 10-20 minutes, it now requires the speed to be reduced to below 50mm/min at 100% power in order to cut through the same material. Everything else is functioning normally, and I always use it with an air assist.I don’t know if it’s something related to the LightBurn software, as it seems to have occurred after I performed the latest update.
