Longer Ray5 positioning issue
Fantastic. Yes. Just transition back and forth… or ask Longer to switch to millimeter before it does what it needs to do.
Actually, I have another idea.
If you put this into your Edit->Device Settings->Gcode->End Code field you should be able to go on with life as if you didn’t care about this:
G21
I’ve never done it but that should work without fuss.
You know I am actually just gonna run it this way for awhile I have been messing with this problem for over 2 weeks now I am happy we found the problem. I appreciate you and your team staying with the problem. I still have not heard back from Longer support they told me they had seen this before but never had the answer for the fix, I think I am going to send a final email to them with the fix. I was also on a Longer support group on facebook. It took a minute to figure out to navigate Lightburn support forum. Once again thank you for the persistence and quick response. I may go back later and change the device settings it took me awhile to figure out the screenshot mode in Windows 10. I have learned more about my laser, windows 10 and Laserburn I am just ready to play now . I am definitely glad I purchased the program. Thanks again.
Note that I’m a user like you. While you will see LightBurn folks actively and frequently posting here this is predominantly a user forum.
In any case, glad you have something that works for you now. I suspect you’ll be making the suggested change sooner rather than later… The first time you forget to swap units and crash the head. I can’t tell you how many times I’ve forgotten similar workflow requirements.
Enjoy the laser.
Funny I just sat down to look into the settings I seen your post when I reviewing your last post. So Lightburn doesn`t have any actual tech support?
They do. They support on this forum but formally through email at support@lightburnsoftware.com.
so where do I edit this gcode
I specified in the post above…
Same issue. Longer Ray5 using an SD card. I have to shut down every time I finish a print or the next “frame” command will be way off the top of the usable area. Even if I load a different design from the SD card.
Did you review the topic? Does the use of inches apply to you? If so, you may want to review the various remedies listed.
