Longer ray5 x axis is always hard limited unless you close the switch
Got a longer ray5 and if I don’t tape x axis limit closed it just throws hard limit. It won’t home off light burn but homes fine off the machine even with the switch is taped closed. I’m tried resetting the machine up, bought new limit switches and harness. I know I must be missing something I’m new to all this.
have you uploaded the firmware version with limit switches feature?
You might need to invert the limit switch signal. This is parameter $5.
Not possible with a GRBL controller.
  1. Fast to switch, switch closes
  2. Stops and backs off switch until it opens
  3. Slow onto switch until closure is detected
  4. Stops and backs off slowly until the switch opens.
If each axis does not follow this procedure, it is not a Home cycle.
Origin 0,0 is not the same as Home.
