My engraver jumps real fast between destinations. I have changed the cables and the result is still the same. The engraver goes real slow on the Xaxis but shoots like a bullet on the Y axis. I am so confused.
Can you type $$ and enter in console window then copy paste the output here?
[PRODUCER:MKS DLC32]
[V2.20(8M.H35.20230626)]
[VER:1.1h.2023062602:]
[OPT:VPH,63,512]
Target buffer size found
[MSG:Using machine:MKS DLC32]
[MSG:Mode=STA:SSID=CresCommWiFi:Status=Connected:IP=192.168.88.40:MAC=FC-B4-67-86-96-E4]
ok
$0=10
$1=25
$2=0
$3=1
$4=0
$5=0
$6=0
$10=1
$11=0.010
$12=0.002
$13=0
$20=0
$21=0
$22=0
$23=1
$24=25.000
$25=1000.000
$26=250.000
$27=1.000
$28=1000.000
$30=1000.000
$31=0.000
$32=1
$38=0
$39=0
$40=100
$41=40
$42=1700
$43=5
$44=1
$45=1
$50=1
$100=46.375
$101=1488.900
$102=250.000
$103=100.000
$104=100.000
$105=100.000
$110=6000.000
$111=6000.000
$112=1000.000
$113=1000.000
$114=1000.000
$115=1000.000
$120=500.000
$121=500.000
$122=500.000
$123=200.000
$124=200.000
$125=200.000
$130=400.000
$131=400.000
$132=200.000
$133=300.000
$134=300.000
$135=300.000
ok
Where did these settings come from? These are normally set to 80 or 100. It’s no wonder your Y axis flies.
Then you can go here to dial it in.
Machine Settings - LightBurn Documentation
