Hi, I’m looking for recommendations for a new laser.
I currently have 2 lasers (Sculpfun S30 Pro - 10w and Sculpfun S9 - 5w) but I’m on the hunt for a new frame (or the whole laser). I wouldn’t want anything too strong because precision and details in engraving are more important to me. With a too strong laser, I would only get a thicker beam and something on the cutting speed, but I would lose details in the engraving due to the thickness of the beam and the weight of the laser head. It also doesn’t matter to me that it’s closed because I have my own box, but I have a few other things that are important to me:
- shipped from EU warehouse
- responsive user support
- accelerations on both axes so that the laser can really reach the configured speed and still be precise
- G-Code clustering - I don’t have experience with it since Sculpfun doesn’t support it, but from what I’ve read it could help when engraving photos, because currently when I’m engraving them the laser jerks a lot and I guess it’s because the controller can’t process so many commands fast enough (engraving is OK but slower than I would like)
- limit switches
- automatic air assist or M7 / M8 port to be able to connect my external air assist with the relay
- working space about 400x400mm (minimum 380x380mm)
- if the entire laser is with a head, it is important to me that the protection on the laser can be removed so that it does not get stuck on small pieces that occasionally pop out during cutting and that the protective lens can be changed in case it is no longer possible to clean it, as well as the smallest possible thickness laser beams
- at the moment, I mainly cut plywood up to 4mm thick, and the 10w laser seems sufficient to me because the thickness of the beam is small and the cuts are caramelized and not burnt (I mainly use beech, birch, poplar, basswood, walnut and okoume)
At the moment, Acmer P2 and Algolaser (Alpha/Delta) have caught my eye.
- Acmer P2 because it has linear guides on both axes, therefore in theory it should be stable at higher speeds and accelerations (P2 of 33W has $120=1600 and $121=900. On Sculpfun I use $120=1000 and $121=500 because that configuration seemed like the best balanced for what I need) but on it the protection on the laser head is not removable, G-Code clustering does not seem to be supported.
- Algolaser (Alpha/Delta) because it supports G-Code clustering, but I haven’t found information anywhere about which accelerations it uses and I’m not sure how much the change in the size of the laser beam depending on the power is reflected in the grayscale engraving and there are some negative comments about QC in the official Facebook support group.
Thank you!
