Looking for advice on cutting out a square part with accurate outer dimensions and then have holes within this square part that are also accurate dimensions.
Do I have to use two different settings? One with Kerf Offset outside for the outer square perimeter and then a different setting with Kerf offset inside for the holes within the square?
I am going to test this, but I will be wasting some material figuring it out…
Inward means “into the shape”, and Outward means “away from the shape”. If the shape has a hole, like the image above it picks the appropriate direction for the hole. Otherwise you would need holes on their own layers with identical settings just to get the kerf correct, and that’s not unnecessarily complicated.
