I’m cutting the test files to check if everything is going accordingly to the original file.
- it makes horizontal lines
- It makes small vertical lines
- It cuts the part out
But then you see the laser losing it’s position.
Can I get some support on my Question?
There is not enough information here for us to say much. It would be helpful to post the original file. I can’t tell what it’s supposed to do. Maybe someone else does.
Part of the problem is that this ended up in the Ruida controllers section. So most of us are probably clueless. Hopefully someone will move it to the correct place.
