i have lost my optimization tab that hangs below the “start from” button. can someone please tell me how to get it back.
thanks
Window > Reset To Default Layout
Have you read the docs?
no, I didn’t, should have and will. new engraver new software. I had been using a co2 with different prog. thanks for letting me know what to do.
Reading the documentation is always a good idea, but let’s get you looking for the correct setting first. While the suggestion will reset the window layout to the default positions, this will not resolve your question.
You may have turned ‘Beginner Mode’ on, which would remove the Cut Optimization button along with other more advanced feature UI elements. Turn that Off (red) and you should have back as you expect.
got it thank you
