I somehow managed to lose the laser control in Lightburn. I’m using an Otur laser engraver.
Did you check under the couch cushions?
What do you mean by “lost control”? Can you be more specific?
The Window menu in LB will allow you to reset the layout, or show and hide various parts of the layout. If none of those options work, you can close LB, and hold shift while reopening it. That will reset the layout as well.
Thanks, I’ll give it a try.
Russ
The window disappeared. Blake’s suggestion fixed the issue. I didn’t check under the cushions however, I did check under the laser engraver and the workbench.
Got it. I didn’t understand that it was the window that was missing. Glad Blake helped you get it sorted out. He’s pretty good at that.
