LT-4LDS-V2 already emits power in standby
I’m using a NEJE master 2S plus. Now I have installed a Laser Tree LT-4LDS-V2 laser module. Works great. However, this laser emits too much power in standby and gives burn marks on its path of movement. How can I fix this? The program I’m using is Lightburn 1.6.03
Maybe this doc helps.
Thanks for your response,
I have looked at it but it is not the problem. The problem is that the laser emits a small amount of power before the command is given. See the fine burning lines in the photo.
I have also updated the firmware but that does not give any result either.
Type
$$ enter
on Lightburn console window and copy paste here the output.
$0=10
$1=25
$2=0
$3=3
$4=0
$5=0
$6=0
$10=1
$11=0.010
$12=0.002
$13=0
$20=0
$21=0
$22=1
$23=1
$24=250.000
$25=1000.000
$26=255
$27=1.000
$30=1000
$31=0
$32=1
$100=80.000
$101=80.000
$102=80.000
$110=4000.000
$111=4000.000
$112=4000.000
$120=200.000
$121=200.000
$122=200.000
$130=255.000
$131=440.000
$132=150.000
Check the items under our job quality troubleshooting guide for when move actions are burned: Troubleshooting: Laser Keeps Firing During Travel Moves - LightBurn Documentation
yes! found the problem. The motherboard was defective. As a result, it did not react in the right way. I installed a new one and this solved the problem. Thank you all for thinking along in this.
