Lumitool & Lightburn
I have a Lumitool laser. After sending it to Lumitool for a USB connection update and now getting it back, I’m at a bit of a loss.
Unfortunately Lumitool did not provide me with any instructions for connecting to Lightburn.
I think I need a driver for the USB connection. Does anyone have the file/driver? I have written to Lumitool but have not yet received a reply…
Many thanks for your help
Oliver from Cologne
*** Translated with DeepL Translate: The world's most accurate translator (free version) ***
It’s likely just a driver in Windows… Have you tried to update the driver?
It’s always wise to contact the vendor, you just have to wait.
Unfortunately, I did not receive a driver when I returned the laser. Do you have the same laser and can you give me the driver? So far I have not received any feedback from Lumitool.
I don’t run Windows, I have Ubuntu Linux, so I can’t help you out with a driver.
If this has worked in the past, there is no reason to think you don’t have access to the driver for your board.
Maybe someone else has a similar machine that they lead you to a driver.
The vendor should be able to supply that or at least where to get it.
You can also search on your laser, windows and drivers via google or some other search engine.
Welcome.
Did you download and install the Lumitool soft(800MB)?
Perhaps the driver is in there…
Yes, but unfortunately this is only an “Android” emulator for PC, as the Lumitool software only runs on Iphone (very limited there) and Android. There is no native software for PC and the USB driver is not yet included. Lumitool is still very much in its infancy (was a Kickstarter project).
Unfortunately, no one is responding and without the USB driver, the connection to Lightburn is probably not possible… ;-(
Post a picture of your controller, close to the chips near usb port.
Also read here, it seems you have to wait a bit more
Lumitool already offers to upgrade the laser with a USB connection.
You can send your laser back and it will be upgraded accordingly.
I’ve had mine back for a few days now, but unfortunately I didn’t receive a driver on a USB stick or a note with the download link with the parcel.
I would now like to test/install the laser and only need the driver/settings.
Unfortunately, I have not yet received any feedback from Lumitool.
Perhaps someone here has the relevant files / information?
Greetings from Cologne
Oliver
