I have just received Cohesion3d board to replace existing M2 Nano Controller Board, on inspection of the stepper motor pins on the Nano Board, i see that the X axis header has no cable attached, i pealed back the protective wrapping and it looks like Y cable has been folded back (assumption on my part !) would have to do a bit of a de-construct to prove this…should i be worried about this and just plug in the Y axis only to the new Cohesion3D Board
My 12month old K40 was working ok, until a month ago, then Whisperer stopped talking to the K40, i decided to get a Cohesion3d cont. board and LightBurn Software.---------Regarding the old M2Nano which was working, with only the Y lead connected, as shown in the previous pic… ---------About peel back protective covering, Picture attached should explain, will have to dis-assemble stuff in the cutting bay to discover the rest of the cable.
So to recap, the Nano system was working, with only the Y axis connected (This seems strange), with the new Cohesion3D set up, should i be looking for the missing X stepper cable ?
--------------I will trace back to the Y stepper motor and let u know…
Trevor
Regarding my issue with the fold back of the Y stepper cable i was able to find that it was just the shortening of the cable.
I agree with u re the Y axis and Ribbon cable configuration mentioned in "Here is another possible wiring configuration of the K40. I refer to this one as the “Ribbon Cable + Screw Terminal Power Supply” Variant. So can i presume to connect ribbon and Y axis plug as shown in … Thanks Trevor
