Mac OS 10.15.7 - Lightburn 0.9.23 - Shapeoko standard SO3 I am sorry to ask this question. I am frustrated because not having used Lightburn in a while, I now cannot get it to jog correctly. After running my Shapeoko CNC, I run the following Macro but to no avail. Any help would be very much appreciated, thank you.
Current behaviour:
Home button and home symbol bring the laser to home at top right.
Z axis operates for correct amount in correct direction.
Jog press brings laser in -Y direction and does not stop
Jog press bring laser in -X direction and does not stop
Jog press brings laser in diagonal direction towards -X and -Y thus and does not stop
It’s not always obvious. LightBurn’s work area is used to clamp movement to your machine limits - it’s not intended to be a document size. For that I’d suggest just drawing a rectangle with one of the tool layers, and lock it if you don’t want it moved.
Yes, it was my mistake in thinking that the work area equated to the size of the workpiece. Your suggestion is a good one and I will follow that. The software performed faultlessly (and as expected) once I had woken up. Thanks Oz.
