i upgrade the sculpfun S9 with the 33W kit .the issue is that the machine coordinates for the X and Y axes cause the machine collide with the frame aswel the X and the Y axis
I set the coordinates for a 400 x 410 workspace . I entered these in Lightburn.if someone has a solution for this?
Looks like you have the wrong coordinates. See below
Coordinates Should be X = 375 mm and Y = 380 mm
pgrading a Sculpfun S9 with the S30 Ultra 33W laser module and limit switch kit reduces the actual working area of the machine slightly to X = 375 mm and Y = 380 mm. [1, 2]
Key Details of the Upgrade Size & Specs
Standard S9 Working Area: Originally around 410 mm Ă— 410 mm (or up to 410 mm Ă— 925 mm if using an Engraving Area Expansion Kit). [1]
Post-Upgrade Working Area: Reduces to approximately 375 mm Ă— 380 mm due to the physical size of the larger 33W laser head and the installation of the limit switches. [1, 2]
Module Weight & Performance Note: The 33W module is significantly heavier and larger than the stock S9 5.5W laser. Because of the extra inertia, you may need to lower your speeds (e.g., around 10–15 mm/s for detailed line work) to prevent subtle jagged lines or ringing effects on text outlines. [1, 2, 3]
