Machine jams/skipped steps w/ lightburn, but runs fine in Openbuilds w/ saved g-code
Running an image file normally in Lightburn leads to my machine jamming, making crazy sounds, and then it will keep going way out of bounds. However, if i set it up in Lightburn, save the g-code file, close lightburn and run it in Openbuilds control software, it runs flawlessly every time. And help would be greatly appreciated.
Nobody huh? Really could use some help with this.
I think I’m having similar issues. Somehow, something has gone wrong with the Lightburn gcode setup I used to use. But I can’t even run it in Control because it wants to flip everything 180 and start from the Right Rear vs the Left Front homing spot.
