Hello
in rdworks I can load the machine parameters without being connected to see the parameters on the other hand on lightburn if we are not connected we do not load anything why ??
Because you are not online with your machine. The values in RDWorks are āoldā from the last time the machine was online.
Hello
why rdworks does it without connection its would be good if lightburn could allow to see a configuration without connection
I asked about this. There are many times it would be nice to āpull upā a configuration file and look at it.
The response was that it was never designed to read them in without being connected.
Itās too bad, it would be beneficial when trying to help others.
You can look at the files with a text editorā¦
How will you read your Ruida configuration when the machine is not accessible? Isnāt it always the latest data from the last time the computer and Ruida were connected that you read in RDWorks offline?
I imagine it as internet, I can also read everything that is in the browserās cash, but also no more than this - without being online. Do I see it completely wrong?
Your view of the Internet is nice, but the browsers cache is not on the āInternetā itās on your computer. It would be more like attempting to use your browser with no Internet connection.
Lightburn or RDWorks would have no way to know whatās happened while on-line or not.
I have a 6442G controller⦠if I replace it with another 6442G controller, how would any software package running remotely know there was a change?
I can change it at the console while Lightburn is connected and Lightburn doesnāt know it has been changed unless I āreadā it again.
Itās simply that it was designed to read from a controller on invocation. Sometimes itās not easy to modify the architecture from something that was, in the early design, a specific way of handling something.
Only the development team can answer that in more detailā¦
hello
I know that you have to be connected to the machine to modify but as the person said before it would be good to be able to look at these parameters without connection to possibly help others
Not quite as convenient but you could save an offline copy of the settings.
I do have multiple copies of different machine configurations. You cannot āloadā a file if the controller isnāt connected.
You are beating a dead horseā¦
Thatās actually what I write or at least mean by it.
Hello
on the other hand it would be good to be able to set the parameters without being connected to calculate the machining time the programs are not done in the workshop but in the house so I do not know how lightburn calculates the machining time in a standard way or if it is base to parameter
because sometimes I have a big difference between calculated and real time
āEdit ā Device Settings ā Additional settingsā
These are the parameters that Lightburn uses to compute job time.
